Looks like those are input boxes for coordinates of a single location (custom coordinates).
I might have found a way to reproduce this faulty behavior:
Create a new FarmEvent using a sequence that uses a location variable with coordinates as the default value.
Select the group with locations (plants, points etc.). Everything works as expected so far, no input boxes.
Open the dropdown menu and select the same sequence or another sequence with coordinates as default value.
Input boxes appear even when there is already a group chosen.
So if it happened the same way in your case, this is obviously a bug in the webapp.
