My Z-axis motor will not stop moving whenever it finds home during a sequence. It gets back to zero and then very slowly creeps upward. It was working perfectly fine last week. Has anybody else had this problem?
@Intelbotfarmer
Update to previous comment:
It is now not the Z-axis, but the X-axis. It will not stop at the home location and tries to overpower the track.
Maybe turn on the X encoder and repeat the calibration? I’m fairly new, but working through movement stuff right now…
On second thought - turn off “enable endstops” - unless you actually installed end-stops. Hope this helps. . .
