Add unique id/label in the mqtt log message
#1
Hi,
When i sent a message to the Farmbot i can sent a unique ID/label with the command from an external application. It would be nice to see this ID/Label in the logs again so i can relate the succes messages to command that was send earlier.
#2
For background info, see:
This feature would require FarmBot OS to keep track of which command caused a log message to be created.
