I can reproduce this and will investigate a solution. Seems to require prior configuration of static wired network, maybe. Is that your situation @bcatanzaro ?
[edit 0] Maybe dhcp wired also crashes ? Workaround is to simply re-flash FBOS to the micro SDHC.
[edit 1] Here’s the full crash detail in case someone can spot a simple fix quickly
[edit 2] Hi @RickCarlino
VintageNet.scan "wlan0"
returns {:error, :unsupported}
when the wlan0
interface is disconnected. Do we recode Configurator to temporarily bring up a WiFi AP on wlan0
so that we can scan !? I don’t know what that’ll do to the running wired Ethernet interface ! . . seems like a lot of extra coding just to allow full WiFi setup Maybe we simply delete the WiFi option when we’re running on wired ?
The “workaround” /usual practice of re-flashing to do Configuration of a different interface is Ok, no?
