OK.
I have been sniffing around and cannot find what I am looking for. Probably a bad search on my part.
I am looking for some documentation about the code stacks used and how to contribute to them.
So far I have heard about the OSS, firmware, FB code base and sequences but not seen anything that shows them lined up and where each piece of the puzzle is stored. I am a noob in this area and I did struggle with Github to navigate.
Is there a diagram that shows the tech stack and then describes how someone can make code changes / suggestions to the code base?
I am new in this language, but I have re-written the ‘Water-all’ sequences, making it module and more robust, including API call retires over a 3-minute period in case the wifi glitches and causes an API failure.
My changes to this area are two fold.
- i created a structured approach to the sequences (that seems to work) Coding styles within FB eco system and
- Resilient code that helps protect against network glitches
Improved watering sequence
I am not the worlds best programmer but it does work (as far as I can tell). Same for the structured approach.
How do I contribute to the code base and who is the arbiter? How does that work on this code as an open-source project? Someone must decide
