I have been attempting to improve the watering experience to make more resilient hence the focus on the UTM connection improvement and I now offer up my coding methods for comment.
My sequence looks like this
The coding style here (LAUNCHER / SEQ / SUB comes from here)
The code for ‘Water all’ is now a SUB sequence of the launcher about. The Launcher sets up the watering head doing checks to make sure it worked to prevent a water drill being sent to water plants
My code replaced this one line
points = api({method = "GET", url = "/api/points"})
and make it check until it gets a good read - or failed after 3 minutes.
local watering_time = variable("Watering Time (Seconds)")
start_time = os.time() * 1000
-- New code is below
local theNumberOfAllowableNetworkTries = 9
local theSecondsDelayBetweenRetries = 20
local failedToGetPoints = 1
local points
while( theNumberOfAllowableNetworkTries > 0 )
do
theNumberOfAllowableNetworkTries = theNumberOfAllowableNetworkTries -1
if points then
toast("Plant list obtained", "info")
theNumberOfAllowableNetworkTries = 0
failedToGetPoints = 0
else
toast("Error - Unable to obtain list of plants (Retrying)", "warn")
wait (theSecondsDelayBetweenRetries * 1000)
end
end
if (failedToGetPoints == 1) then
toast("Fatal Error - Unable to obtain list of plants (EXITING)", "error")
return
end
-- end of new code
local plants = {}
for k, v in pairs(points) do
if v.pointer_type == "Plant" then
table.insert(plants, {name = v.name, x = v.x, y = v.y})
end
end
table.sort(plants, function(l, r)
-- "close enough" approximation.
if math.abs(l.x - r.x) < 150 then
return l.y < r.y
else
return l.x < r.x
end
end)
count = 0
total = #plants
job = "Watering all " .. total .. " plants"
send_message(
"info",
"Watering all " .. total .. " plants for " .. watering_time .. " seconds each",
"toast")
for k, v in pairs(plants) do
coordinates = "(" .. v.x .. ", " .. v.y .. ")"
set_job_progress(job, {
percent = 100 * (count) / total,
status = "Moving to " .. (v.name or "plant") .. " at " .. coordinates,
time = start_time
move_absolute(v.x, v.y, 0)
percent = 100 * (count + 0.5) / total,
status = "Watering " .. (v.name or "plant") .. " for " .. watering_time .. " seconds",
time = start_time
write_pin(8, "digital", 1)
wait(watering_time * 1000)
write_pin(8, "digital", 0)
count = count + 1
end
percent = 100,
status = "Complete",
time = start_time
Comments anyone?
