I am trying to get some servos working and am not sure where I am going wrong.
I am using the Set Servo Angle Farmware which I am assuming sends a PWM signal to the pin defined in the Farmware config, in my case I am using pins 4 and 5. The sequence is as follows:
I’m super stuck at this point. Can @Gabriel or anyone from Farmbot suggest something I can try?
The only other route I can see is to add a uController like an Arduino pro mini to my custom tool and signal it via write-pin block.
I’m investigating the issue. In the meantime you could enable firmware logs in the logs page settings menu to make sure the command is being sent. (You should see an F61 if it is.) Be sure to disable firmware logs again after to not affect web browser performance.
