I have always been frustrated that after a head change, the FB would often not detect the new head. Additionally, I had issues with the soil moisture sensor coming off in the ground during the retraction phase of movement as the connection force was not strong enough to stay connected.
Using the magnets that came with FB tools, and purchasing some cheap magnets and screws from Temu, I have come up with a far better solution.
It solved the connection reliability issue AND the head connection strength issue.
NOTE: The magnets are already rusted prior to the experiments.
1 - Replace the magnets in the UTM with the Fat one from the strimmer head - Note the orientation of the magnets as they are upside down. Place two washers under the magnet to add a little bit of space. Do not use the cheesehead screw but make sure to use the flat head type. This increased the magnetic flux significantly by allowing the magnets to be really close.
2 - Ensure the screw used to secure the magnets to the tool are flat. They will get VERY close to the magnets in the UTM and cause a strong magnetic bond.
3 - Insert two washers under the B & C screws to ensure a good amount of pressure on the POGO pins.
This addresses the hardware aspects and I have also written software to support a ‘safe’ head loading as well. That can be found here. In the very rare event of the detection failing now, it will put the head back and try again 5 times to improve chances of getting a connection.
https://forum.farmbot.org/t/unreliable-head-detection/9781/12
The combination should solve the UTM tool head change reliability issue.
To be honest, we should move to an optical detection such as this kind of thing. I have ordered one to play with but it would remove the detection issue permanently.
I know it is a bit messy at the moment and I intend to put together a better parts list and instructions but I just wanted to get it out there and see if anyone is interested.
