I built a rather long sequence by my standards. It consists of 70 very simple steps and I called it “new Water-all_plants”.
The sequence actually only consists of 40 different points that are approached and the opening and closing of the water periphery and a few times waiting. That’s all. When I run the sequence, it transfers it correctly, but nothing happens.
Oh, I wasn’t aware of those public sharing constraints.
What do you mean “it transfers it correctly” ?
Do you see a Log message “Starting <your sequence name>” ?
Have you tried putting common sequence steps into a new sequence and just calling (executing) it where needed in your “main/big” sequence ? ( i.e. simplifying and reducing the number of steps )
Quick info for anyone who also has the same problem at times, with a sequence not executing.
Here is the solution: I have split my very long sequence with 70 steps in three smaller sequences with about 26 steps each. Then I created a new fourth sequence to call the three smaller sequences. With this workaround everything works fine.
Bug(s) I think. If there’s a known Step Limit for any Sequence it should be made clear to the user.
In your initial sequence which included 70 steps, the FarmbotOS would have had a process crash (unreported), which would have looked like the screen capture below, on your IEx Console ( I’m currently using “edit/test/crash” heuristics to determine the upper step number limit in practice )
edit - 39 steps including 9 MOVE , 18 CONTROL PERIPHERAL, 9 WAIT and 3 other “small” steps will make a process crash and exit ( unhandled exception )
If you have a GitHub account you’re welcome to submit a new Issue based on your post here.
There does seem to be scope for “software product improvement” here
@Kay I’ve found the bug, tested a solution and will submit a Pull Request tomorrow.
When released, expect FBOS to reliably execute a single Sequence containing > 100 steps.
Thank you for helping troubleshoot and fix this issue @jsimmonds! I just tested your PR using FBOS v15.3.1-rc1 on the beta channel. However, I am still experiencing the issue where the bot silently does nothing when trying to run a sequence with a high number of steps. I am maxing out around 35 to 40 steps as well.
Oh woops! Looks like I had a moment of dyslexia and was testing with the wrong version.
I just tested again with v15.3.2-rc1 on the alpha channel. And… it works! I tested with a sequence to move a relative distance of 10mm, 100 times. We’ll get this released soon Thank you so much for another bug fix @jsimmonds! And thank you @Kay for reporting the issue.
