Hi
I am having intermittent connection issues with the UTM when mounting tools such as the watering tool. It is a new build and all of the connections are clean. Any thoughts?
Hi
Take a read through the UTM troubleshooting documentation:
Hi
The issue is intermittent. I wiggle of the head and the connection is made so it ‘appears’ to be mechanical in nature - hence my thoughts towards improving the magnets.
You may also consider adding the dedicated watering nozzle. This will eliminate a significant amount of the tool switching to do the watering.
You may also consider lubricating the UTM pins with some graphite spray.
Marc
