Using FarmbotOS beta updates
How many kmsg_tailer processes is enough ? (21 ?) Raspberry Pi 3 B+ on 8.0.0-rc41
( Only went looking because poor old RingLogger got duplicate after duplicate of the dmesg message set :slight_smile: )
Oh, and also, why is udhcpc running on my wired interface ??
< D’Oh, of course, it needs to renew leases and all that jazz . . sorry >
Lol. Getting connected to NervesHub often requires restarting :nerves_runtime which apparently doesn’t cleanup after itself. Really I only use that for development so maybe I’ll just disable it in production releases.
As for the udhcpc on eth0, I assume you are using static? That could cause problems if there is a DHCP server running. I’ll make a ticket for that one
Hey, thanks @connor, pls. don’t bother with that udhcpc on eth0 mention !
I corrected my misteak with an edit which you may have missed.
DHCP wired works well, and, I haven’t bothered trying "static" "wired" _ because I didn’t know that VintageNet supports it yet (?)
I’m fairly certain it does but I haven’t tested it personally
Hmmm . . I tried just now . . all good except there’s no /etc/resolv.conf created so no DNS lookups.
@connor, that NTP servers issue is not entirely repeatable . . previous Factory Reset (5 minutes ago) Configurator correctly did its magic and plugged in my desired names.
Next Factory Reset just now, I got the out-of-the-box default names (4 of them) instead.
I’ll dig deeper . . as I’m still looking at why the Configurator AP is so slooooooooow.
( currently using v8.0.0-rc46 as .IMG downloaded )
P.S. What do I need to do to build :iw on Ubuntu 18.04.2 ? Here’s my failure
apt-get install pkg-config libnl-genl-3-dev -y
This is very strange. maybe i’ll change the check from where it is now to where credentials get checked. Will have another update coming up
I just had a realization on why it probably isn’t working for you.
Farmbot only resets NTP after the device connects to the internet currently. Obviously if the device can’t reach the first NTP servers, it won’t be able to connect to the internet due to SSL cert errors etc. I’ve moved the check to when a network interface
becomes lower_up which for ethernet means the cable is plugged in, and for wifi means the ap has been associated with. I hope this will fix it. https://github.com/FarmBot/farmbot_os/pull/867
Thanks for all your help testing!
Thanks for all your recent amazing coding !
Hey, { You code, I test } == win<–>win :slight_smile:
Re: that DNS resolver issue with static wired config . . should I send it to VintageNet or do you think it’s a User-problem ( i.e. FarmBotOS coding ) ?
< I know this NTP server user-specified issue is not a big one, but it’s functionality that pre-existsed and it’s also desirable for School, College, Uni. networks that are usually hyper-managed. >
I think the NTP issue should be fixed now. The DNS issue is currently open on VintageNet if I remember correctly
The ā€˜NTP issue’ does seem to be fixed now, thanks.
Thanks, too, for that hint to get :iw built . . with the aid of asdf I’m building firmware again ! Yay :small_airplane:
AND, unexpectedly, the Configurator AP is back to being responsive (!!) . . I wonder why ?
Now running -rc46 commit 2ba6c31f . :slight_smile: .
There was an update to the DNS settings on the configutor AP. This may have fixed it. hopefully Frank Hunleth is working on a proper fix to not require IW
Thanks @connor . . I’ll test all that soon as it’s ready.
Meantime, spoke too soon about that Configurator AP performance . . after 1st Factory Reset, it’s back to its bad old unresponsive ways. Now that I can build again, I can debug :wink:
A new one. WiFi Regulatory Domain is not passed into persisted network config. It’s stuck at "US"
< added with edit >
Also, VintageNet.Technology.WiFi starts the AP with country: US, not country: 00 as the code suggests it should do.
here is the DNS issue i was talking about
Yeah in the Config of the Farmbot application i have it set to US. Maybe i should default it to 00 world at boot and default configuration to US but allow users to supply it.
I’ve opened a pr here to allow changing regulatory domain
RC47 should now have better support for regulatory domain. Interested to see if it helps with your ā€œslowā€ configurator issues
Now testing on -rc50 at commit 6315b224 and have a couple of observations.
  • The Configurator AP is now completely unusable for me (here in AU). I’m trying to investigate and will try to compare host_mode in VintageNet with the prior NervesNetwork behaviour.
    If there’s a user in a Country outside US that’s willing to test Configurator, that’d be excellent.
    Seems that the WiFi layer is Ok and stable (auth, associate) but the ARP and IP layers are ā€œcactusā€ (very unreliable).
  • Can’t get the Farmduino v1.4 firmware on-line . . but do get some nice cyan debug logs
  • There’s a (repeatable) very debouncey :slight_smile: Pin Binding log during 1st synch. ( minor issue ? )
Now testing on v8.0.0-rc52 at commit 89835f06 built from src
  • Configurator AP still unusable (I’ll try another RPi3B+ just in case)
  • First boot Firmware flashing now works again (?!) and still have cyan debug log dumps during upload of fbos_config JSON
  • CircuitsGPIOHandler still very debouncey
Now testing on v8.0.0-rc53 from the CI .IMG file from GitHub
  • Configurrrrator AP still almost useless . . if you persist trying long enough (1.5 hour ?) you will eventually get the web-site to work long enough to configure the Bot.
  • After first boot, firmware ( farmduino_k14 ) connects and runs fine.
    After any shutdown and restart, connection to Farmduino firmware can never be re-established ! . . despite n x flash firmware attempts from the Firmware pop-up on the Device page ( picture follows) . . . time to burn a new SDHC :confused:
< new news re: firmware >
Use WebApp Device -> FIRMWARE dropdown to set firmware None
then set firmware Farmduino (Genesis v1.4) revives the connection :sunny:
< new news re: Configurator AP >
@connor and @Gabriel there’s good news on the Configurator’s WiFi AP . . today I used a different RPi3B+ board and the AP is working very nicely (i.e. as expected).
Puzzling failure on that particular RPi3B+ I was using . . it always worked fine as a WiFi Client . . just not much good as an Access Point :confused:
Further testing on v8.0.0-rc53 configuring a wireless network connection reveals that the WiFi Regulatory Domain ( country ) is ( still ) not persisted from the Configurator Advanced form.
Remains as default 'US'.
