2019-08-26T14:00:00Z
Ha! I think I see the problem /boot/config.txt says dtparam=spi=on so the WebApp front-end should not be offering pins Pi GPIO 7,8,9,10,11 for Pin Binding
Have an enormous ElixirConf US 2019 ! . . . blow their socks off with FarmBot OS v8
2019-09-05T14:00:00Z
Hi @connor, do you need me to open Issues for the 3 remaining problems in 8.0.0-rc64 ?
Also, can you tell me where the following [debug] logger messages originate ?
I want to try fixing them too.
Seems you’ve ‘nailed’ ( fixed **even more** ) the problem above of full recovery after an “Internet” outage, so thanks for that.
Testing today 2019-09-12T14:00:00Z on 8.0.0-rc80 and just noticed that the package includes all the artefacts for the farmbot 8.0.0-rc68 release also !?
Apologies! I actually didn’t see this thread get created for some reason. I’m currently working through these today, and am hoping to get a recover deploy out early this week with fixes for this stuff. Will keep you updated!
I’ve discovered that the :mdns_lite app is emitting those [debug] IGNORING log records.
I’ll see if I can fix it and post something over in their repo.
The WebApp PIN BINDING list is much shorter now But I suspect even little old Pi GPIO 4 should also be off limits because I get this after Binding it first time :
espeak“kind `a works” ™ ( very chopped-up audio and only on HDMI )
2019-12-12T13:00:00Z
Testing on Pre-Release v8.2.4-rc7
Looking a heap better in many ways ( Thanks @connor )
Farmwares work normally ( no OpenCV issue )
Sequences which include multiple Farmwares ( e.g. take-photo ) run to completion !
Still needing fixes
timing race around pipes/CeleryScript compiler/AST still shows up occasionally
and aborts a running Sequence.
Wonder if a fix similar to one of your farmware.ex fixes is a patch for this ? ( swallow up that :DOWN message so it won’t propagate )
Sequences with multiple Farmware calls now seem to be completely reliable.
( Deft refactoring by @connor )
espeak issues persist.
Now testing Pre-Release v9.0.0-rc4
espeak issues still persist ( nothing on analogue out ; very chopped-up audio on HDMI )
The Network Quality pings from the WebApp now result in one Logger message per “ping” !
Also, the response from the device is published into MQTT ( wasn’t happening in v8.2.4 )
Hi @RickCarlino . . notice your team is back at work big-time ( no Xmas break yet ? 0-: )
Just tried FBOS Pre-Release v9.0.0-rc9 and it won’t fly for me . . see image following.
I saw issues with FirmwareReset.NULL.init function in the log output (serial) and then Linux re-boot >> loop <<.
Glad to help ! @RickCarlino, on this topic, I was thinking recently that a little bit of automation to “smoke-test” these Pre-Release versions might be a good thing ?
Seems all fixed in Pre-Release v9.0.1-rc1.
Just noticed today that :mdns_lite seems to have stopped working ( responding ) . . maybe after a recent deps versions update ?
